Root Anybody running CM7 source?
Just flashed 46 over 45. It took forever to reboot, but seems stable. Also I was able(had to) to reinstall the battery % from mattyg as well.
Thanks and I like the way you think. ;)
You guys have probably seen this, but while we are on the subject-- in CM sound settings you can push alarms, notifications, and phone calls to always play on speakers. I listen to audiobooks while I sleep, so this helps a lot.
I am flashing 46 over 41 right now lol. It's hard to keep up! I am thankful we are geting this level of dedication from the developers! So awesome.
Question on the "quiet hours" in CM settings. If you don't choose the mute notifications options, will it still work? Do the sounds just come through but at a pre-determined low volume of some sort?
I've been using an app Timeriffic for some time now, and it's free. (I think) But it allows you to do exactly what you want. I have it set at a particular time to dim brightness, turn off all notification sounds, set the ring volume to any level you want, vibrate for calls but not for email.. etc. Things like that. Then in the morning at a preset time everything goes back to daytime settings. It even has a weekend time slot that you can adjust. The really nice thing is that you can set it and then forget it. No need to mess with multiple clicks to set up everything every day.
Sorry for the delay. Here is my process.
You need to mount the card: mount -o remount,rw /dev/null /system then do adb push (the .apk) to the system/app directory. Then adb remount and it will show up in the app drawer. If you have any questions post them and I'll try to walk you through it.
Heads up for those who have installed or are about to install build 46. The video recording is broken again. You may want to hold off flashing until it is fixed.
I'm running #46 and I can't believe how smooth this is running. The only thing I've noticed that doesn't work is the lock screen music controls. Can't wait for the release candidates to start rolling out!
i am ikn love with this rom and i have no problems at all
x2!!! Except for the occasional issue, which seems pretty easily fixed
havent had a single issue that was major, or a reason to need a different rom temporarily. I never use camcorder anyhow, so that meant nothing to me .. but i think that is fixed now
man i couldent tell ya bro i have been flashing this rom over its self for about 10 builds and i d k that might me helping me not to sure if it would or not
I'm struggling to get GApps working with this ROM. I'm using the latest nightly and then I flashed GApps. Well, damn, I have Gmail and other Google Apps but under Settings -> Accounts and Sync I cannot add a Google account.. only an Exchange Server. Ideas?
Camcorder and AdFree are only things not working for me right now. For an alpha, it is sooooo good so far.
I love it!
