Math-Uhhh-Saurus Well-Known Member Sep 20, 2010 #1 It isn't in the market. Is there anyway I can still get it? (I hope this is in the right forum)
death2all110 Android Expert Sep 20, 2010 #2 Here is the apk. place on sdcard and use astro file manager to install or if you're comfortable with adb you can do it that way. I dont have time to type up how to install apps via adb, class in 10 min. Attachments com.appdroid.anycut.apk com.appdroid.anycut.apk 31.3 KB · Views: 332
Math-Uhhh-Saurus Well-Known Member Sep 20, 2010 #3 death2all110 said: Here is the apk. place on sdcard and use astro file manager to install or if you're comfortable with adb you can do it that way. I dont have time to type up how to install apps via adb, class in 10 min. Click to expand... I installed astro file manager and then tried clicking on the link, but it says "Cannot download. The content is not supported on this phone." oh wait...never mind...didn't read the entire post...I can't put it on my sd card right now (work comp doesn't have a reader)
death2all110 Android Expert Sep 20, 2010 #4 Well good luck! and i believe there is a setting somewhere in astro that allows you to download any file type in the stock browser
Math-Uhhh-Saurus Well-Known Member Sep 20, 2010 #5 death2all110 said: Well good luck! and i believe there is a setting somewhere in astro that allows you to download any file type in the stock browser Click to expand... Yay! it worked :] Thanks
death2all110 Android Expert Sep 20, 2010 #6 Im guessing you found the setting? Good. Glad i could help out!
