Asterdroid
Android Expert
Swype sucks. I use shapewriter.
Too bad it's no longer being supported.
I like using Swype and feel like I could get pretty fast with it after a little practice.
My issue, is that once I set the input method to Swype, I woulld like an easier way to switch back to regular input. The reason is that I get mail from my work's secure exchange server and have to input a security key to unlock the phone. It is harder to do this accurately with Swype (I think). I have not been able to figure out how to change the input method once I am at the the unlock screen.
Anyone know how to have the keyboard reset to the default or how to get a specific input screen to show up for the unlock screen?
if you long press the message box of the text message, it will give you the option of input method, select/press INPUT METHOD and choose your options.
I really loved swype until I had to go through the whole beta process and re install it on my dinc. Since then it seems to predict in a different language and comes up with some really weird suggestions that I cannot figure out. Here is an example:
"This is a test of swype on my droid incredible", which use to come out perfectly, now comes out as "Tua is a test of swype in by sous incredible"
I promise I am not doing anything differently and the prediction used to be absolutely perfect. Now I can't type simple words like "this" without getting "tua" as well as many other different incorrect predictions. It drives me nuts because I simply can't use swype because of all the corrections I have to make.
ANY IDEAS??
Tried that but after hitting the swype button, there is no option to delete the word. There are simply a myriad of other words including:
tuia
egida
ruota
tholos
ethos
riposa
ripida
but no "this". It's almost as if it's set to another language however I have checked and rechecked every setting and nothing is different. This is so effing frustrating.
