Root aosp roms
teamevo88
I'm currently running kings unleashed 3. I want to use the Wii mote for nesoid but heard it only works for aosp roms. I saw the kings gingerbread but the link was down. Any good aosp roms that have working hdmi mirroring and 4g working?
I recommend Kings GB R2. Try this link.
Cool..do I need something else? Thought I read somewhere that I need caulkin format zip or something?
Here are the dl instructions and you can find Kings format all zip and gaaps here:
Install Instructions:
Download Kings Gingerbread R2
Download Kings format all Zip
Download Kings Google apps flashable zip
Download Kings custom GB wallpaper
wipe data factory reset
wipe cache partition
wipe dalvik
Flash Kings Format all Zip
Flash GB Rom
First boot will take a bit of time!
Then Flash Kings Google apps flashable zip
Most of us use it. Its just basically a fast wipe tool and helps u snot to forget something. You can grab it in the rom and kernel link in my sig, its near the top. Flashes just like anything else.
I use the 4.3.1 nosbc kernal and get great battery life. Can I still use it or do I need to get another one?
Netarchy kernels are for sense based ROM's, if you flash an AOSP ROM, you'll need to flash AOSP based kernels. I recommend Savagedzen 1.01 cfs, it's comparable to netarchy in terms of battery life.
Though i believe netarchy does make some "universal" kernels which technically should work with aosp, or cm7.
Salvage Zen is working pretty good on my phone. Only issuer I have is the battery indicator. Shows the percentage by 5s
Have not had any success with Tiamat, I would recommend SZ;)
What issues have you had? I tried SZ 1.0.1 about a week ago and my phone got all sluggish at one point when I got a call and a text at the same time and I ended up having to reboot it. I've never had any issues with Tiamat.
With all that said, I still want to try SZ again sometime, because I can never be satisfied with status quo. :)
I fear that MIUI includes the sbc version of tiamat, so i'll be looking for that noSbc version (I am all caught up in the sbc panic lol). Will also be trying SavagedZen 1.0.1
