Help Auto Alphabetize Apps?
D
Deleted User
Guest
Is there a way to make it maintain alphabetical order after u download something new?
If there is i cannot figure it out, other than manually dragging them from one page in the app folder/drawer to another and then sticking it in the proper spot ... which is a pain
Launcher Pro automatically sorts the apps alphabetically. You can also hide the stuff you don't use. ;)
If I install launcher pro can you still keep the touchwiz look of the icons in the app drawer?
I think the OP wants to have Grid view alphabeticalized which outside of using LP I dont think we can turn this on per se
