Root Automatically booting directly into ClockWork Recovery
On my previous devices, OG Droid, Incredible, I had to press and hold a button while powering up to boot into recovery. On my Thunderbolt, every time I power on my phone it boots directly into recovery, even if I only press the power button and no others. Today I had my first random reboot and it booted into recovery and the screen was on for at least an hour in my pocket.
Is this recovery boot process by design, or did I do something wrong? If I did something wrong, any ideas on what I can do to fix it?
Im having the same problem, and that fix didnt work for me, also i cant turn my phone off, it turns off, then all of a sudden cw recovery just pops up
Go ahead and flash a custom rom. Battery life is great. No bloat to drain the battery so bump charging isn't a huge issue.
Well, I'm rooted and my battery life is fine WHILE I'M USING IT. At night it runs down to nothing and cuts off no matter what the charge level was before. Any ideas? SetCPU doesn't seem to work until we get a custom kernel. What's funny is for the first few days of owning this thing it was fine. It only used maybe 10 percent overnight. But now it uses all of it.
I have done all of the saving tips and really don't have anything different than from my Dinc. I'm at a loss here.
Any new apps or changes since you started getting bad battery life? Any updates to apps? Maybe some settings were defaulted when an app updated itself?
Setcpu does work on stock kernel. But your nighttime problem is troublesome since it should throttle down to 245. You using night clock or something like that?
No. My setup is almost identical to what I had on my Dinc and there were no problems there. I run Setcpu and when I underclock it it will still shoot up to 1024 and stay there. So, I'm getting no help from that.
I have minimal syncing going on, low backlight, etc...Something is just eating it up.
What kind of signal are you getting at your house? Take a look at the battery stats and report what your % of cell standby time without signal is.
Yeah but that's just for data. The phone will still try to connect to towers for the cell and txt part. If you get poor reception it can kill a battery.
Well, I'm still having problems. Funny that I get great battery life when I'm using it but not when it's asleep. Last night I was able to charge it to 100%, unplug it then go to bed. When I woke up I had 49%. Here are the battery stats for that period:
http://img862.imageshack.us/img862/1061/screenshot2r.png
edit: fixing my image
Yep same thing is happening with mine. I can't get fast boot to work either, in fact the only time mine has ever worked was when I first installed Virus Rom. Stock never worked, after I rooted and installed the new stock ROM didn't work, and it doesn't work on Das Bamf either.
I'm thinking it is an app I have installed that doesn't like it, however I don't care about it enough to go through trouble shooting which app it is.
After reading about the fast boot method, I tried it didn't work...then I turned off data and all running apps...It worked now I can charge w/phone off
Hmmmm that would seem to point to my theory that it is an app that is causing the problems with fastboot. I will try your method (kill all of my apps with System Panel) and let you guys know if that works. I don't see any problems killing all apps if you are powering down.
Found this over at thunderboltforum.com
All credit goes to a guy names FlyersFan121. I have yet to try this but i will this weekend.
Rooted Thunderbolt bump charge fix
I wasn't sure if I was to post this in General Discussion or down here in development so here goes:
I'm sure some of you may be aware of the rooted Thunderbolt issue where you plug in your A/C Adapter to charge it with the phone off and it boots into Clockwork. There have been fixes posted about enabling FastBoot fixing the issue. I was having this issue as well and I enabled FastBoot and was still having the issue. I did come up with a fix for it.
If you are still having the issue turn your phone on and disable FastBoot. Then shut it down. Turn it back on and let it boot up. Then go in and enable FastBoot. Now turn it off. Boot it back up one more time (you should notice a significant increase in boot speed.) Charge it until it turns green while on and then unplug it and shut it down. Now plug it back in and you should be good to go.
This worked for me...I did have to go through this to get it to charge while off (and it no longer boots into Clockwork Recovery.)
Good luck!
its interesting that that works,if it does. it sounds like way too much trouble for a lil bit of extra charge,for me anyway. :eek:
i guess if you only had to do that process once it wouldnt be so bad,but if you gotta do that every monring to bump charge it sounds like a hassle.
Yeah that is what i was thinking too.
