OC, Sd-ext, woyuld be my major things I would like, been running Stayboogy's blue rom, as it gave both oc and sd-ext.. and so far so good (would also love these on my l35G, but oh well lol)
Stayboogy's roms support Sd-ext native, well no extra stuff needed on my end anyway, just repartitioning the SD cardI have Stayboogy's 777MHz OC and a SD-EXT partition for Link2SD with this ROM and they work fine. Am I misunderstanding what you'd like?
Hey, out of ideas - it's been almost a month since last ROM update announce already) is it upcoming 4th of July present for all of us?![]()
Happy Independence day!Maybe. It does seem like I end up doing stuff around holidays.![]()
does this rom toss out all the at&t junk files, and most importantly does it remove the auto-update feature that att added to it, if so i'm going to be putting this on an avail ASAP, just wish there was a way to back up apps and then put them back, as i'll loose so many nice scores in so many games, lolx.
you can backup apps with titanium backup and just restore them
It's rooted so thats weird. the binary is out of date as I havent updated in a bit, so try updating from Superuser.
Also, that update.zip might be older, not too sure and too busy to checxk right now, but THIS THREAD
http://androidforums.com/avail-all-things-root/678701-root-update-zip-root.html is still open so it's probably more up to date. Try that.
If not, your problem is probably the CWM6. you got it from that other site? I've seen more than a few reports of problems arising from that in this forum(Lost recovery mode, etc.)
If the update.zip doesn't fix your issues, you might want to try touchnav.
I'm using an old cwm5 that unfortunately isn't linked on here anymore and have no problems.
let me know if either of those help. either way probably going to push out an update by next weekend.
