Root Babbling...Stuff to think about
rhino889a
Android Expert
I .am homeless and lost my 5 computers. couldnt pay storage.My cellphones help take care of my geek or nerd needs.I try to open every single file possible. So things i write hear are just random memories of files i have opened.This may give you all something new to think about or not.
quote from a script ( lets make some fake battery stats ) WTF?
quote ( checking for sound card .no sound card make phone crash)
somewhere along development lg reuduced recieve buffer size almost by half.
it seems our phone can run on 2.4gig, 4.9gig ,5 gig low,5gigmid,5 high,possibly a 9 gig band.
localle changin to other country may create a few more wifi channels and allow higher tx power
CHECK UPDATER SCRIPT ON ANYTHING... I INSTALL MANUALLY.. SOME NEED RECONFIGURE I POSTED TO VIEW MAY NOT BE RIGHT AN NEED MODIFICATION
wifi locked to 16db ? 32db is [possible? iwmuliticall iwconfig wifi tx power app can be used to raise or lower db (maybe phone next to router use 4db ) phone FAR from from wifi use 32db
i think symlinking needs for thiese to work correctly
iwconfig https://www.dropbox.com/s/2bj4mdlt7ljp027/iwconfig.tar
setwifi power iwmultical
https://www.dropbox.com/s/9pfafo3vrumw401/set_power_wifi.zip
ipv4 tweak
https://www.dropbox.com/s/1e9qsrhl41ipns1/DataSpeedBoost_signed.zip
https://play.google.com/store/apps/...pper.WiFiTxPower&feature=search_result#?t=W10.
i forgot the other applets multicall can use iwspy ifconfig iwgetid ???
info apps
ipconfig app https://play.google.com/store/apps/details?id=com.mankind.ipconfig
ifconfig app https://play.google.com/store/apps/...unasoft.ifconfig&feature=search_result#?t=W10.
mY phone has files called PITTPATT what is PITTPATT Seems it is a FACIAL REQUOCNITION SOFTWARE.but i dont see how to use t5his feature. google buys pittpatt
Google Buys Facial Recognition Company PittPatt - Search Engine Watch (#SEW)
they are sneaky cfg and ini mirrored by other cfg and ini you cant just change one file and see effects.the mirrror file reverts the changed file Persist?
inject settings in several ways cfg ini conf modules .the phone phone has many different settings for the same thing ,just a matter of which one takes effect.
Can i take apart foreign kernel ,rom or module,firmware and use what i want. (i want best RADIO capability)
several (LG CHANGE) only depend on local or a true or false setting somewhere
RECIEVE 0- 128 128 is more range set at 128 Can it go beyond 128?
Phone is made for several carriers in several countries
Kernel supports swap partition.Make several small swap partitions on sdcard instead of 1 large one.phone will read and write much faster AT LEAST I WOULD THINK SO
I have a SWAPCONF file for ease need to reconfigure for our phone. https://www.dropbox.com/s/s1z3ppz27q9bu00/update-OR-swapconf-v.0.2b.zip
Memory module Does it over ride service.jar?
adding modules? seems like easy way to modify kernel and settings
have not used this
https://www.dropbox.com/s/veooyr7kk...tcher_Tools_RC7_TEST2_ALL_DEX_Windows.exe.zip
Can make both cpu online almost work like a desktop FASTER
this is flashable or installed as an app
http://forum.xda-developers.com/showthread.php?t=1719934
https://play.google.com/store/apps/details?id=rs.pedjaapps.KernelTuner
also android tuner works
a few links
Dual Core - force both cpu-s online-Alpha2
i Used PIMP MY ROM to install INITD. apps like android tuner ,kernel tuner can make scripts so app isnt needed at boot
Android tuner has a SCRIPT WRITING feature
I think this Kernel can go beyond 1.5 g on cpu, just find where to put settings.
### I think this phone is NOTHING.
####It was made to barely function.
###We have no Utilization of the Real Power of this device.
Unlocking Bootloader For some reason i have a feeling its simple its just burried in a muck of deciet symlinked trickery smoke and mirrors.
At the cofee house getting bored, add more later
seems phone has a setting for QUICKCHARGE cant find how to activate
what is rats? i think its something they use to control battery tempurature,is in updates
#####coming from comunications background rf transmission linear rfamps,phase lock loop,modifying radios for more watt output adding more range of frequencies stuff like that i want to let you know about routers
i think its ddrt or somethig like that, modified firmware to flash certain routers, you can make wifi routers more powerful run on foreign channels and turn wifi router into wifi repeaters. many possibilities
Main Page - DD-WRT Wiki
www.dd-wrt.com | Unleash Your Router
is the signed image the bootlogo?,the second one is different from the first. i have seen a third little blip of logo on boot, i think it was after modifying something.
Why is it that some apps are in a zip form after they are installed?
Ipsysctl
Ipsysctl tutorial 1.0.4
That's heavy duty. If you need to vent we are here for you. Or pm me. Things are darkest before the light. I like were you are going with this. I bet unlocking is easier than it seems.
yeah its funny if you read everything the dev talks to . We chown this, untill we talk to google we disable this,If this we that,Sometimes its like a Naration to the coding.
LOL i cant remember as i said i have tried to view every single file the phone has. but i will see if i can come up with that.
Do you know what ONESHOT is?
Blah blah blah
ONESHOT
DISABLED
Code:
service bootlogo /sbin/bootlogo_l0
class main
user root
group root
disabled
oneshot
I have no idea...
Lookie here in init.l0
Code:
on post-fs-data
    setprop ro.crypto.keyfile.userdata /dev/block/platform/msm_sdcc.1/by-name/encrypt
on boot
    chmod 0660 /dev/ttyGS0
    chown system system /dev/ttyGS0
There was another i think checks the timing of when script starts like must initiate at proper time, like security check.
Its like You tried to slip in a script after boot UHH UHHH UH NO NO NO DISABLE DISABLE DISABLE THEY ARE SNEAKY I AM TELLING YOU
well it kind of makes sense as you dont want to start setting up system links and permissions on certain files and trying to run certain scripts from /system/etc before you mount the system partition at boot...
oneshot means the script/service is ran once and when it exits thats all there is to it instead of a service that stays on
oh ok, that makes sense thank you, i have seen a few, many oneshots are at boot, after they run i can change them, thats why my settings are not permanent. somethings i change last untill reboot or a change.such as radio service turned on or off.
though some of the files i am refering to are opposite of what you are saying, as if the script started later than suppose to and it knows uh uh uh denied
Are u homeless?
yeah for awhile now. i get bo9red and try to disect everyfile on our phone,i get mad that my motion doesnt display all files and some are truncated but i now have a laptop that i think i may be able to view contents of files like .ko .so .lib .bin and such t5hat my motion wont open correctly
i have seen some weird sh### in a few scripts. they knew we would get root access no matter what they did.so my impression the didnt try to stop root very well but concentrated and burrying and twisting files to make full control hard.
EDIT another thing i like to do is stare at my screen when i am doing virus scan or backup or recovery. you know when every file is quickly displayed as its scanned or written. they fly by superfast. i read those and know where it is and what it does, sorta like a flashcard system
sleep under a bridge, i go to starbucks for wifi and tricity, or after 5 when bussiness close i found a building or 2 that has 110 outside.i hijack wifi from businesses when i cant afford metro (which throttled me to like 100k on unlimited because i used to much bandwidth,in top 5 users) i bought a small 12 volt battery like for ups backup security cams or sauch. i caan charge and use my phones pretty much all day
Looking at CLEAR.com a 4g service (not phone } that has real unlimited service they claim 6meg down. i have a google phone number and grooveip so i can make and recieve calls through wifi when metro not paid.
sorta one of a kind homeless guy here,others recycle cans,steal copper ,i carry a battery 2motions optimus m admire,a soldering iron and a vbunjch of chargers, sell mma fight dvds.
i was given a broken laptop i carried around for 2 months untill i got a hard drive to install, i just got a matched pair of 2 gig memory chips to put in. gonna try dualboot windows and possibly ubuntu when i get a chance, i am collecting root tools an such to make a few bucks here n there workin on peoples phones till i get a job again.
http://www.clear.com/
clear uses wimax which is what sprints old 4g network used. and can be fairly expensive to start up. i would honestly look into freedompop. they offer wimax 4g coverage via clear/sprint. they offer a mifi and usb stick, they cost 100/50 respectively but its just a security deposit that you can get back. they offer 3 plans;
500MB's a month for free
2GB's for 18 a month
4GB's for 29 a month
obviously there is a big initial investment but if you can keep usage under 500MB's a month you could have a free mobile hotspot every month :)
(who knows maybe some generous souls on here would even donate to help you out....)
edit: ok appears they stopped selling those devices and now only offer an ipod touch sleeve (rather sad IMO) but here is one on ebay for sale or if youd rather trust amazon...
Wireless Internet — Mobile 4G Wireless Internet Access from CLEAR
Sorry to hear about your situation. My heart goes out to you. Although I was not homeless ( at times, to close for comfort ) I was out of work for two and a half years, till about three months ago. Things are starting to improve. Good luck to you.
Thanks for the concern guys, i am sure things will go my way sometime. and shabby clear has said i can get a transceiver modem for 50 and unlimited service for 45 or 49 something like that with thier discount they are offering.the modem will support 8 devices, thats if i am, not to late i talked to them over a week ago, i thought i would have the money by now, its about 115 for modem and 1 month, shipping is free with discount
but checkin that site now
yea man id look into it i mean its not unl but for 100 bucks you cna grab a hotspot activate it online and get 500MB's free for a month and then upgrade if you need
Sounds like you're really going through some stuff man, thanks for the information.
Stay up & stay SAFE
no sweat, i am still learning android,i just wanted people to know what this phone might be able to do, i want the 5 gig wifi,i think i saw 9gig band on a file, must be for overseas use. oh and faST CHARGE CAPABLE,if i can get around some of this maze of scripts and mirrored and link persist files and crap, i dont have to have u8nlock so bad.i thinkthis kernel can be overclocked,from what i u7nderstand it already is.
i never had a cellphone till i was homeless.my first one was a basic phone, then i got an admire,found this site and realized its just a mini laptop with user restrictions.i was big on computers and modifications, ran a few online gaming servers using a few rAckmounts i bought and sent to Peer1 data center i8n new york.So i remotley handled those and a few teamspeak servers i rented slots for gaming clans,at that time a buddy i meant playing medal of honor started a clan called thelostbattalion. those machines were win 2000 server i8 think. but it was great having a personal dually on huge pipe for my own use,torrents ftp gaming,the other servers paid for it all. after 1 week i had my first computer i was fixing dll and irq problems but didnt know how to copy and paste.lol anyways satarbucks is closed and i am in an industrial zone now where the bussinesses are closed and theres 110 and the Wic cewnter has a very weak wifi. i downloaded a movie yesterday i want to finish.
also check bottom of 1st post ddwrt very interesting modified firmware for wifi routers
