Root Babbling...Stuff to think about
From whaf i can tell the disabled Wiper interface has to di with Gps.It seems it helps with more pinpoint acuracy. It might be for Wifi Gps. The info i have is vague.
We already havd the apk in system apps
And the manifest would indicate it is for wifi
Disabled Treadahead is readahead or preload. Seems it has something to do with bootup
http://www.google.com/url?sa=t&sour...BTfumDWG_wT9HC9Bg&sig2=vC3oKiEJPtgCPdOLz48ElQ
Another disabled at boot is NFS SERVER
network file system server
Network File System (NFS) is a distributed
file system protocol originally developed by
Sun Microsystems in 1984,
[1]
allowing a
user on a client computer to access files
over a network in a manner similar to how
local storage is accessed. NFS, like many
other protocols, builds on the Open
Network Computing Remote Procedure Call
(ONC RPC) system. The Network File
System is an open standard defined in
RFCs, allowing anyone to implement the
protocol.
I dont know what this is . But it looks cool
Lol
This is pdobably simular to what i was refering to
#!/system/bin/sh
sysid=`cat /proc/cmdline | grep system1`
if [ -n "$sysid" ]; then
sysid=1
fi
if ! applypatch -c EMMC:/dev/block/platform/msm_sdcc.1/by-name/recovery:8345600:709eb5e5a7217f6c55aba73d517fd9106f1a2094; then
log -t recovery "Installing new recovery image"
applypatch EMMC:/dev/block/platform/msm_sdcc.1/by-name/boot$sysid:5601280:17286989ac2411291d6f03fc77e7d298990ab603 EMMC:/dev/block/platform/msm_sdcc.1/by-name/recovery 709eb5e5a7217f6c55aba73d517fd9106f1a2094 8345600 17286989ac2411291d6f03fc77e7d298990ab603:/system/recovery-from-boot.p
else
log -t recovery "Recovery image already installed"
fi
Look at init.rc it calls for this apparently
service flash_recovery /system/etc/install-recovery.sh
class main
oneshot
Hey does anybody remember the guy from metropcs that won a motion at a metro seminar
His phone was version b an ran at 1500
He made a post along time ago
Pretty sure was at this forums but cant be sure
Does anybody ever extract .apk s and read manifests and stuff
Like fota apk
Or hiddenmenus apk
Permission are coded in numbers and letters
Secret code numbers.
Weird stuff
Try it when you get board .you might find something cool.
Can we boot a whole rom from our sd card. ?
You know like that cm 10
Or collab roms
For testing reasons or whatever
To help transfer heat from my battery to the plastic backplate i put copper tape on the backpkate. To hekp
Has anybody tried putting a dose of cpu heat transfer compound
Like artic siiver i forgot what its called to hekp dissipate theheat
My copper tape makes sure there us full contact from battery to backpkate
Heat transfers a little better
I am considering getting a tiny cpu heatsink and taking it to the automotive shop and having sawed down reak thin then gluing it to the outside of backpkate
It may help as acting like a Kickstand for watching movies n stuff
Something like that would probably be better.. Voltage Regulator heat sinks..
Thats what i need. Am homeless now so my motion is an xbox television,downloader,laptop ,sometimes its a phone to
It never gets turned off and is always charging so i sorta worry bout heat
I put it on cold metal , concrete even. Put my phone on a bag of ice
Often i take the backcover off for ventilation
You have your xbox connected to your phone?
Has anybody overclocked the graphics processor
My motions are running on version c
Can you guys post the other versions build props
I want to see the. Rat managment settings and a few other things
Especially untouched build props or clearly obvious where the modificstions are
