Hi all,
I was trying to change the boot image while running. I did it with the following commads (in adb shell):
Apparently, it didn't work. But now, when I try to use tools like flash_image, I receive the following error messages:
I tried erase using fastboot, and flash image, and I still get:
What does it mean? Did my device damaged?
Code:
cat /dev/zero > /dev/mtd/mtd2
cat newimage.img > /dev/mtd/mtd2
/sdcard # flash_image boot boot_2.6.35.7_2.3.6_fuse_rooted_bgu.img
flashing boot from boot_2.6.35.7_2.3.6_fuse_rooted_bgu.img
mtd: not writing bad block at 0x00000000 (ret 1 errno 2)
mtd: not writing bad block at 0x00040000 (ret 1 errno 2)
mtd: not writing bad block at 0x00080000 (ret 1 errno 2)
writing 'boot'... FAILED (remote: Write Fail)
