Help bad lag using audio playe
bonerp
Android Expert
My note was suffering seriously bad lag when using the audio player at the same time. I couldn't use the web!. Anyone else had this? Sometimes its laggy scrolling too. Apart from size of screen my s2 was much better than this device.
Dolphin hd is using 120mb ram too!
Any ideas? Got same apps as on the s2.
What official rom are people using in the UK? - Sim Free
Thanks
The only lag that I get is sometimes when I switch to the home screen the phone sometimes has a think for a couple of seconds. I have seen no lag or problems playing music while browsing the web. I have tried two firmware versions. The one delivered with the phone and an OTA update. Both were quite smooth.
I have an unlocked international Note from Austria.
Regards,
Eric Ritchie.
well I have downloaded and installed via odin 1.85 the LA4 rom (stated as Open Germany).
WOW - its as smooth as my s2 and runs on around 100mb ram less than before. ALL of the choppy scrolling has gone too. Will check status when using with audio player but so far soooo glad i installed this.
All I did was extract the HOME.tar file from samfirmware and place it in PDA box, check auto boot and f reset.time, put device in download mode, kick it off and it then restarts.
Awesomeness of S2 once again :)
I too find this. Im on fw N7000DDLB1. Scrolling the Music player is like pain. it only captures my gesture after few seconds and scroll too slow.
Is this bcoz of some kind of Bug on this FW (Official on from Samsung). With the dual core it has everything should be buttery smooth but except the games and the apps most of the stock one lags.....
Is there any one with the same ver. has this prob.
Any help greatly Appreciated!
I'm on the same FW. Flash AbyssKernel 4.1 (not 4.2) or Franco Kernel 6. Both remove any lag whatsoever.
Where u exp the same lag after upgrading to this FW???
Can you please Help me the procedure and the file to flash??
