So I'm on the first gingerbread root leak and I just went to look at my battery bar made with minimalistic text and it is accurate to the 1%. Anyone else notice this? I'm not sure what happened..
Yes I know those widgets do that but minimalistic never did until today.. Was there an update? I dont have it auto updating.
.as far as i know anything that does 1% increments is an estimation
scary is there a way you can make battmonx into a widget that displays the battery information along with cpu temp? it would be a very nifty thing!
). I'll be "attending" virtually from my PC at home, though (they are going to "simulcast" the sessions, I believe)).
either way i always have battmonx runninga widget form of battmonx will be amazing bud, give it that good look feeling to it you know, that way once people have it set up they can either remove the notification and apply the widget to their homescreen, or keep botheither way i always have battmonx running
minimalistic text has done 1% for me for several months. on both froyo and now GB. You can see it being discussed along with circle battery back in February here http://androidforums.com/droid-x-all-things-root/278435-1-battery-stats-circle-battery-widget.html
I also think there was another thread (that escapes me at the moment) where I learned of the Circle Battery Widget (full credit to that dev for doing the 1% thing first (at least that's where I heard about it first)). Very cool!
People were like "no way"....and the response became a resounding, "way!"![]()
Think it was this thread. http://androidforums.com/motorola-droid-x/280042-battery-level-1-increments.html
