The iphone has a cult following--a fanatical defense of the iphone from any criticism, and a craving idolatry of all things Apple.
The Android phones did not have this cult nuttiness, at first. Now it seems that any reasonable criticism is simply not acceptable. Oh well, reasonableness was good while it lasted.
Now, to the point. The lack of a replaceable battery is definitely a shortcoming of this phone. My Evo 4G battery issue was readily solved by a 3500 mah battery that I could swap out, allowing heavy usage and total mobility from early morning to late evening. Not so with the LTE.
HTC is not stupid, so I am hopeful that the next iteration of this fine device will have a replaceable battery.
My LTE is a work phone, as was my 4G--work busy from 7AM to 6PM, then my personal phone from 6PM to midnight. This can only be done if I take advantage of every opportunity to charge it throughout the day. Thus, it is less reliable and less mobile than my old Evo 4G with the 3500 mah battery.
I imagine this will result in an iphone-cult like response. Oh well.
Sorry you're having trouble but that's no reason to march in here and be condescending to everyone. Please don't do that.
If you want to detail your situation and post specifics we may be able to help.
Are you in a fringe area? Are you losing power over a reception issue? Have you had Sprint perform an RF box test to ensure that you don't have faulty radios?
Are you on wifi for any portion of the day? Are you on LTE all day?
How many hours of screen on time are you getting per charge?
Last two times I heard of trouble that bad, the phones were defective, replaced and problem solved.
Can't advise you on anything without more information.
