malek can you link it here so we can look through it?
Geolocalisation fix (aka no-sleep bug) | drakaz
Not sure how relevant it will be to the DX, but it's a start.
Someone else reported this last week too. That was the thread that got me looking at this issue here.So I am testing this out and can also repeat it. I am seeing that my Handcent SMS seems to be very high on partial wake usage. Anyone else having problems with this?
They just updated it to fix that bug.The new Facebook app doesn't seem to negatively affect the phone going to sleep for me. For me anyways, it just seems to be the GPS.
Same issue here - thanks for the heads up. But I am not sure how to fix it? The only thing I use GPS for is navigation really. So after I use navigation I need to reboot my phone? I had been manually turning off GPS but it still was running at 100% - thanks
it doesn't matter if you leave it on or off after you toggle it...
it seems that as soon as you manually turn of the gps it kills whatever script is still running in the background (no matter if you turn it back on or leave it off)...
that being said, ANYTIME the gps is then accessed afterwards, the "evil" script comes back on so you have to toggle the gps again...
for now i'm just leaving my gps off...i'm getting much better battery life...it sucks that something that should automatically work doesn't but i'm really fine with for now just manually adjusting the gps when i need it...
I'd suggest you start a new thread as this appears to be an entirely different issue. My guess is you still had something else running that was masking this problem. Try your issue with a fresh reboot, but let's not confuse the issue at hand here.This bug is not limited to GPS...
My DX WiFi was doing the exact same thing. While WiFi was On 100%, it was also Running 100%. Tried rebooting... didn't fix a thing.
Now that i updated my FB, it does Not Sleep. So, Yes, i had the same issues with GPS in the pass, NOW, if i run FB, it will not sleep (unless you cycle GPS). IE. Even if GPS is off, and i go to FB. it will not sleep. If i Cycle GPS (in my case ON then OFF), it will sleep..I had the GPS sleep issue even before I installed Facebook. So I know it's not that, at least not for me.
Seriously, you guys should go talk to the people in the Samsung Galaxy(i7500) forums, since they have the same gps - no sleep issue that we have
No just cycle the GPS off (and back on again if you wish) and that is enough. A reboot isn't necessary.
I guess I never noticed this because when I use maps I turn on the GPS and then turn it off when I'm done with it.
kapstone..I see the same. Toggling does not prevent running 100% for me. Only a reboot seems to work.
