Larry_ThaGr81
Member
Which kernel would offer you the best battery life?
Everything on all four phones are the same with the exception of the kernels they are running. Choice of phone isn't important because the same kind of phone is used for each scenario below.
Phone one has the bekit stock voltage 600MHz kernel clocked to 600MHz.
Phone two has the bekit low voltage 800MHz kernel clocked to 600MHz.
Phone three has the bekit low voltage 1000MHz kernel clocked to 600MHz assuming that frequency is a option with SetCpu.
Phone four has the bekit increased voltage 1100Mhz kernel clocked to 600MHz assuming that frequency is a option with SetCpu.
