Works great! Thanks guys!
Jedii hit the nail on the head but just to expand. This icon will give you the exact same reading as all battery apps and widgets since they all read/display the same info.Would this be more accurate than battery widgets that take their % from the system? For example, my battery tends to charge full, and then when I pull out the cord, the widget reads 98%. Gyea?
I agree I like it, simple yet classy...just like San Diego^^ Nice post with the photos, I just installed it and I think it looks cool.
Plus it gives me a chance to use ShootMe, Im like a addict with that app
And I took the weekend off from posting hereNot the only thing you're addicted to right now, Mr. 1000+ posts ....
Can you install this over a different theme? Or will it blow out the old one?
Nice!
Thanks for this. I also was able to finally rid myself of a dedicated battery widget.
I was wondering if it was possible to keep the bar showing the amount of charge left while having the charging symbol as opposed to animating. It would be easier to tell how far along charging is.
So how do I exactly install this if I have Clockwork and ROM Manager installed?
Just follow the step by step instructions I provided in the OP
Its very simple.
Yep, that was a lot easier than I thought. I backed up yesterday, so I went straight to boot from recovery through ROM. Just a bit scary when navigating through recovery mode. Thanks again.
I asked you some follow up questions in your other post like thisNice! I need this, the stock one sucks. I tried to install CWM but Odin keeps freezing when i try and start the CWMRecovery.tar file in Odin. Anyone else having this problem? or know of a solution? I've tried all the compatibility modes and it still freezes...
http://forum.xda-developers.com/showthread.php?t=724778 (had wrong link up in my 1st try)
