Help Battery %
There are widgets on the market that do this, but it is separate from the display on the right. To get it on the right hand display, you will have to root. Personally, I use circle battery widget which is great, and does not contribute to battery drain.
you know how do the root please?
Yes I know how to root. Should not be done if you are not familiar. There is much information at xda forum.
cheers, maybe you can talk me though it ? if you have some time use skype?
i wanna learn :D
i just signed up that fourm. 4million users wow.
People can't become familiar without a bit of guidance. ;)
Adamantell, have a read of [CF-Root v3.7] and the other root-related threads in the XDA Galaxy S II Development forum.
If you have any questions post them in our Galaxy S 2 - All Things Root sub-forum and hopefully someone can answer them. It won't be me though - I'm still trying to get my head around the process after nearly two years working with HTC handsets!
WOW !!!! THANKS gonna go read this, yeh i just been reading about it, seems hard like
thanks all help
I want to be kind. You are not ready to root. Need to educate yourself, then I you think it would be helpful then try.
