Using the beats audio file from RockoDev @ XDA is a success!!!
The results below were recorded utilizing the Line In port on my PC plugged directly into the headphone Jack of the LG Connect Running Broken Out ROM V1.0 and Power Amp. I modified the bass level of Power Amp to 75% for the EXPLICIT Purpose of having the frequencies drop when the bass hit! I also raised Tone to 25% and Set the Equalizer to Extreme Bass.
The following provides us with physical proof that we can see with our own eyes that Beats Audio DOES make a difference, whether slightly inaudible or not.
Audiophiles rejoice, I proved yo' shit a success!
Credits go to RockoDev for this, I take no credit for anything except trying, and failing, then trying again, and succeeding. (And testing, and providing proof)
Before you read further, if you don't follow instructions, or for some reason your phone just doesn't like this, and it breaks it - It's not my fault, nor RockoDev either. Follow the instructions carefully (not like it's hard) and you shouldn't have any issues, but if you do that's what the restore is for.
Beats can be obtained by using this direct link HERE
OR...
You can use the QR Code listed: HERE
The entire thread including other versions can be found here: XDA Forums Thread
Installation Instructions:
1. Root your phone, if it isn't already.
2. Download the zip file, and place it somewhere on your external Microsd card. it HAS to be on the external.
3. Reboot into Custom Recovery Mode
4. Create a Backup of your ENTIRE Rom (This is known as a NANDROID Backup.)
5. After that's finished, Select the menu that says "Install Zip from SDCard."
6. Select the Beats zip file, and install it.
7. Reboot phone when prompted to, and enjoy.
8. Post if you notice an audible difference, and what headphones you're using so we all know what sounds best to our ears, not just what looks best.
9. Ignore the following two posts referring to an Issue. Those are in reference to an issue with a previously aforementioned version.
10. Stop reading...seriously, there's nothing down here xD
Please give thanks to RockoDev @ XDA if you like this. I did nothing more than test, and therefor don't take credit for anything.
To remove this, simply restore the nandroid backup you performed earlier in the steps for installation.
Proof Below:
------Ignore the "Using Go" part in the first chat box. I accidentally hit my paste macro and was pasting that text (and a lot that isn't showing) into another thread regarding how Our connects look.--------------------------
SO....In conclusion, to all you haters and doubters GTFO! You tried to say it was impossible, and now I've proved you wrong with more than just my extreme intellect of electronics. To the people it helped, glad I could do it for you, I love providing my "families (communities I join) with content
OR...
Proof Below:
