Root Benslgdroid mdpi cm9 themes
benslgdroid
rockstar
BIZARRO (play store)
https://play.google.com/store/apps/details?id=cm9.theme.bizarro
Based off my cm7 theme bizarro
Clock is fancy widgets pro, folders are folder organizer. Launcher is nova.
H2G2 (play store)
This is based off the number 42 or H2G2.
https://play.google.com/store/apps/details?id=cm9.theme.H2G2
The new wifi icons provided by scar45 of http://pcb.team.broc.co/li/apps/pcb-for-t=mobile-theme-chooser
Halo (play store)
https://play.google.com/store/apps/details?id=cm9.theme.HALO
Fairly simple but I honestly like this the best so far.
Rebel Alliance (play store)
https://play.google.com/store/apps/details?id=cm9.theme.REBELALLIANCE
This is a theme for all my fellow starwars nerds. ;-)
Launcher is nova, clock is fancy widgets.
Imperial star wars (play store)
https://play.google.com/store/apps/details?id=cm9.theme.IMPERIAL
Battery and WiFi icon by kgill7 of xda.
DARK Knight (play store)
This theme is based off the dark knight.
https://play.google.com/store/apps/details?id=cm9.theme.Dark_Knight
to help with themes would be much appreciated
If you have mediafire versions please update to play store versions as they come out because these versions well be what's updated and you will be notified through the play store when updates are available.
Hey have you done the iron man theme yet?
Edit: I ment for m9
Edit I looked on DHoT and didn't see one for cm9
Once I have the rest of these, only two more, fine tuned and up on the play store then I will do a cm9 version if brotherswing is not already planning it out.
Imperial is updated for Google play. WiFi icon has also been fixed, there was an error where it would move back and forth.
