Otterbox has been discussed a bit previously in the thread along with photos. It is the Otterbox Commuter for LG Optimus. It used to say Optimus S, but now is just Optimus.kcobra, can you please provide a link for what you got?
The screen protector doesn't have the notch cut out for the proximity sensor. I picked up a 5 pack of screens for a buck or two when I got my Otterbox.
It is what tells the phone when it is up to your face (so it turns off the screen) or not against your face (so it turns back on the screen). If you cover it, it may not function correctly.proximity sensor? please explain
The screen turns off so your face isn't pressing the buttons on screen. I'm sure it saves battery life too.I'm really confused now. Sounds like the Otterbox Commuter series is the way to go, but is it a big deal to have the proximity sensor covered up? Why do you need the screen to go off when you're talking? Is it just to save the battery?
One poster said his Optimus V fit into the Optimus case with the Otterbox on it. Mine absolutely will not even come close. There was another flip top case discussed that is larger than the case made for the Optimus by the same company as the one I posted. I still haven't gotten around to ordering one yet though. For now I just tuck my phone in the top of my kilt or stuff it into my sporran.Also, the fliptop or folding case that the Otterbox goes inside--do you have to take your phone out of the case to use it?
Would a body glove suffice? Or should I just otterbox? It just seems too much to pay $25 for a case.
Still loving my case! But now I have a question:
With the case on, how to do I reboot the phone when it locks up? Before I'd take the battery out, but that's not so easy with a case. Is there a key combo? I tried holding down the power button for a while but that didn't do anything.
ah , I thought the accelerometer was the thing that detected when the phone was no longer against my head. Where is it, then, do you know?
Unfortunately, the instruction manual just indicates that they are to the right and/or left of the Virgin Mobile logo, but that is a wide area and since they are under the black part of the glass I can't really tell the exact location. Someone in this thread earlier linked a 5 pack of screen protectors that had a notch cut out for the proximity sensor(s), so far that seems like the best indicator of where they are.
Im looking for a case thats good for the Optimus V and will cover up the Virgin Mobile logo on the Optimus V
RE: Otter vs Body Glove
I went with the Otter and think it is a really good case. A little bigger than the BG to be sure, but the protection is superior. I live in a warm climate and my phone has not overheated. As long as you are not charging it while using the GPS with it sitting on the dash on a sunny day and streaming Pandora, you should be fine.
I'm keeping my Otter but just sprang for this one too. Amazon.com: LG Optimus S Sprint Gels: Electronics . It looks like one of the least obtrusive of the gel type wrap-around covers.
