Root Best ICS Rom for Evo??
Okay and would I flash this Rom the same way I flashed MikG? And what all do I wipe before flashing this?
You have to wipe: dalvik cache, cache, and data
I suggest using superwipe as well. It is a .zip file that will wipe everything that is needs to be wiped. I always run it twice just to be sure. Just put the zip file on the root of your sdcard and use the same steps that would be used to flash a rom. Superwipe.zip
Yes, you would flash that Rom the same way you did MikG. Boot into Recovery>Flash zip from sdcard>Choose zip from sdcard>Select the Rom's .zip file.
Assuming you use AmonRa.
Upvote 0
Check out the fixes in the thread for things you should flash.
Anytime you install a new ROM your going to want to do a full wipe. Wipe everything except for SD card (wipe SD-EXT & SD-android.secure), flash superwipe, flash the ROM, flash the kernel, flash everything else). Let it sit for around 10 minutes before playing iwth it once its booted up.
  • Like
Reactions: dkl1 and Nathan2112
Upvote 0
Oh and before I do this, how do I restore all my apps with Titanium Backup? And can you give me a link that is the latest/best version of this Rom?
Here is a link to RX'x thread about the ics rom he was talking about. Don't know if a new version dropped yesterday or not. http://androidforums.com/evo-4g-all-things-root/531349-rom-miui-v4-4-0-4-2-4-13-ics.html
As far as using TB, do you have the pro version? You can do batch operations with it.
you don't want to use it to back up any system app, those are in red. You use it to backup your user apps and data. You do that BEFORE you flash the new rom. :)
Should be after you have made a nandroid too.
Tb is supposed to be able to make a zip of itself you can flash after you flash the new rom that restores the app itself, that you can then use to restore the apps you previously saved.
I can't ever get it to work though, so I used Appsaver to save a copy of the tb and tb pro apks. When I get ready to restore tb, I just use a file manager to browse to the appsaver folder and there they are! I select them and am given the option to install them. Then I use it to restore my apps.
Let us know if you need more specific instruction as to using tb itself in the backup process.
  • Like
Reactions: Nathan2112
Upvote 0
sorry I wasn't clear. :D
Tb saves your apps and data for you. But after you flash a rom, you have to have to have tb on the rom to get to what you have saved with tb.
tb makes a zip to restore tb itself, but I have never been able to make work. Just dumb I guess. :)
That is what i use appsaver for, to have tb on my card so i can restore it/ install it, with the file manager app.
Tb free will just let you backup or restore 1 app at a time. Pro lets you do a bunch at a time.
  • Like
Upvote 0
Okay lol I got it this time:D
Should I also install the kernal below the download link with this Rom as well? If so should I flash both of them at the same time or seperately? Could I also just use app saver instead? Or would it be better to do it the way you do it with tb? And lastly, what link should I use, the one that says "MIUI V4 4.0.4 2/4/13 DUAL SIGNAL BARS" or "DOWNLOAD MIUI 2.4.6"? Thanks.
  • Like
Reactions: dustwun77
Upvote 0
from xda
"How to install
1) Download ROM, place on SD
2) Make a backup of current set up
3) Wipe /data, /system, /cache, /boot partitions
4) Flash ROM
5) Flash ICS kernel (optional)
6) Reboot"
That is a great kernel, I'd flash it. same session.
I used to just use appsaver, can't do batch with free version either.
I like tb and tb pro. I just use appsaver to save the tb apks cause I can't get the tb restore zip to ever work.
  • Like
Upvote 0
Be sure you check out Rx's post. He has given tips you need to know and some links to fixes you will want too.
regarding Tb, as you may know, you can do more with it than back stuff up. you can use the pro version to freeze apps you want to remove but aren't sure what effect deleting them will have.
After they have been frozen for a while without problem, you can use tb to uninstall them too.
Upvote 0
So I rooted my phone 2 days ago and installed Cyanogen mod 7. Loved it, except last night my voicemail notifications stopped. was getting "V30-voicemails will be delivered when data service is available." I was still able to get into all my apps (FB, google+, espn, etc) so I figured it was just a hiccup. Called sprint, they said it was an outage in the area. So this morning, I had NO service. No apps loading, no 3g icons across the top. Called sprint again, spent an hour w/their "tech support" trouble shooting. They didn't even ask me if my phone was rooted/running a ROM and couldn't get why my menu options were different. They were going to mail me out a new phone(well, a replacement EVO4G), so while she was doing that, I used Clockwork Recovery MOD and put my phone back on the HTC ROM. Boom, data and everything works fine now. (sorry for the long explanation, i'm a noob and want to make sure I get everything out for the best response).
Now, my question is, what is the best ROM that I should run? b/c apparently there was something wrong with the Cyanogen Mod 7 that I had due to all these issues since I installed it. Like I said, I just rooted and CM7 was the first one I'd done. It took me about 2 1/2 days to root, so be gentle with your instructions/reccomendations :)
Thanks!
Upvote 0
Upvote 0
BEST TECH IN 2023
Smartphones
