i like decks 1.3 /1.3d . After is flashed and running for about 5-10, then i flash a sbc tiamat kernel (longer battery life) HTC Evo 4G
( 4.1.0sbc) -gingerbread
(always wipe cache and dalvik cache in recovery before/after flashing kernel in recovery)
gingerbread-evo-deck-1.3d.zip (in case the link is broken)
for ics (all ics roms beta or pre-beta) but thus far i like miui ics [ROM][MIUI v4 4.0.4] 2.4.27 - xda-developers
Decks ICS is good as well (hwa) Dev-Host - The Ultimate Free File Hosting / File Sharing Service'
if you change the kernels, make sure its for ics when using ics rom
tiamat ics kernels (dont use the other tiamat kernels other then listed here)
Tiamat_Supersonic-sbc-v031412
Tiamat_Supersonic-v031412
Mason kernels
[KERNEL][WIP] Mason kernel for supersonic v0.14 - xda-developers
Just to clarify, the phone will normally charge to 100% and then stop charging untill it reaches 90%, at which point it will start charging again. It does this to protect the battery. During this entire time the light will be green and the battery will show a 100% charge. So when you take it off of the charger there is usually a 10% drop off while the battery % catches up to where the actual battery is.
SBC charges the battery a little past 100% and keeps it there.
Start with the mason kernel.
Mason-G-v0.14-sbc-fso-supersonic-signed.zip
Wipe dalvik cache & cache & flash
There was a lot of worry about battery damage or explosions when it first starting coming out, but its been out for a long time and the only real issue is that over time the battery *might* wear out faster. But this isnt really a problem because you can get new batteries very cheap.
I use it and really enjoy it. The battery lasts a few hours longer
What is fso? And I have also seen either hwa or what can't remember which. What does that mean?
IMHO the absolute best you can do on gingerbread aosp is deck 1.3d and the mason .15 kernel running the wheatley governor. End of story.
Here is the link. G is for Gingerbread and non HWA ICS roms (which there aren't many now). I is for ICS Roms with hwa, so Deck's, CM9 port, AOKP, Darklight etc.Hey I cant find the Mason .15 Kernal, only the .14 one... can you send me the link to get it? Thanks
can you guys provide the most recent miui rom for evo 4g dowload
