So would the 1750 be worth it? and would i need to get a new case or would the stock one be fine?
The stock cover and any case will fit with the 1750 mAh battery in place as it is OEM size.
Got mine (1750mAh) Saturday. Have run it down fully twice now and allowed 8hr charges. Will run it down again tonight and give it another 8hr charge. It is lasting longer than the 1300, and that is what's expected since it is a larger battery. Right now it's at 54% with moderate use. The 1300 would've been at around 30%. So far so good.![]()
There is no reason to run down a LiON battery. That as for NiCad. LiON doesn't have memory, it has a maximum charge discharge cycle. So you're batter will last longer if you charge it less but while nikel batteries would get a shorter life if you charged them before they were dead. Lithium will charge and discharge fully until it just stops taking a charge.
That would be kind of cool if it didn't make the phone to bulky.
