Bizarre battery problems cropped up during romming
OK guys. Doc... You were right :-). I had a bad battery. So weird. Went from perfectly fine to awful in less than 12 hours. I went to the only place around that had replacements in stock and the only thing they had was an aftermarket 1500 mAh battery. Stock is 1800 mAh. Same size except new one is EVER SO SLIGHTLY thinner. I asked a few people and they said it will work fine. I just wanted to get y'all's thoughts on the matter.
Well I was never much on after market batteries but I do understand that in a pinch they work, I would be careful tho as some i have had in the past actually messed up my phone( leaked, shorted out) but should work till you get the correct one....
But again thats just me lol......
Do they have a return policy? I mean the key is to have it working, but I would order a red 2520 may extended slim, or for 35 bucks you can get two ace 2050 mah batteries plus charging gear for home and car from, and just use the 1500 mah as secondary or until you get a bigger mah one like the 2520. That's what I would do either order a 2520 now or when you can while using the working 1500 mah battery. Maybe when my ace battery comes if you pay shipping will send you one of my two stock batteries if still need. I live in Raleigh if you want to figure out cost.
Thank you Codegerm and gendo420 for pointing that battery out, ordered it up. Also, thank you bilgerryan for suggestions and as always thank you for Project X! Just suggested on Facebook for anyone with a galaxy 2 to get your creation cheers folks! :beer:
Alright I'm starting to get ticked off. Still doesnt seem like its right. In fact, I know it isn't. I just played a video that I had on my SD card, 1/3 screen brightness, charger connected. I lost a few percent!!! Usually if I do anything, as long as its plugged in, it would ALWAYS charge faster than it was consuming, meaning my percentage would increase. I'm so irritated at this point. Something has to be wrong somewhere.
I just flashed 3.0 from el29 after double wiping and its not right. How could I be having an issue like that on a freshly flashed ROM?
First you need to charge the battery fully with out testing and do a total discharge, then from a full charge start testing. In my opinion it has nothing to do with the rom, I would still check your charger also:)
Ya I have changed cables but not the ac to DC aldapter. Maybe I'll try charging it off of the cable box that I use to charge my sixaxis ps3 controllers. Could charging off of that mess anything up? It would be just to try something different than the provided Samsung adapter
I've been on the phone with my brother for the last hour and I had the screen off until he last 15 minutes. With screen off it got up to 83% then while still on the phone I forced the screen to stay on. Normally it would keep on charging but it instead dropped from 83% to 77%. Something is just off about this. We'll see. I'll turn off screen and get it up to 100% then discharge it and retest but I feel it still shouldn't be acting this way.
And I'm back on trusty 2.8
Do me a favor and lets diagnosis this before we start making unsubstantiated comments about someones rom and I'm basing that on, no one else is having this issue that your having, have you ran something like Android System Info to see were the discharge is coming from, have you changed chargers, could it be the after market battery, again it could be something you installed, uninstalled or modified, please do me a favor, before saying its the rom lets look at all aspects of what's going on, there's to many variable's involved here to even say that before we get more info.
I didn't say I was back on 2.8 to down bilgerryans ROM, I simply stated that to inform everyone that I am on a ROM version that's been working great for me for weeks, so as to RULE OUT version 3.0 being the cause to my problems. Its my fault for not communicating that better. I'm sure its not the ROM because I am the only one having this issue and because its now acting funny on both versions, when it never did before.
Project X is still my jam. :-)
I don't care what version you use
  • Like
Reactions: Doc
Man - pretty tangled, that's for sure.
Pretty clear to me that this is better with a focused thread so we can try to help get this all sorted.
I picked an arbitrary starting point, one was as good as any other - but I thought, after the battery replacement seemed pretty good ok.
Trust me I want to go to 3.0 but I think I'll have better luck isolating my problem on 2.8 where I have established myself for the time being. Thanks again bilgerryan. Much respect
My battery is at 99%. Gonna run battery calibration once it goes 100% and let it fully discharge. I'll charge it again to 100% then report back.
Thank you sir :)
Every version of Project X is more than good to go. You are unequivocally having issues from something or things other than the rom man. I can tell you love the rom, just word goings from the mindset that you are having issues you need to solve and are troubleshooting from any point to consider other than the rom. I can show you battery screenshot from any version if you need more proof and j
have posted one maybe a few showing hours with may both mentioned versions. I understand your frustration and am certainly not a developer or in any way a creative source that has worked to make such a great running rom :Project X, but as a noob that has tried other rooms, learned things, messed up, learned, am still learning, and now have confidence to help find your solution, I know that Project X is in no way shape or form the problem just to clarify with you as we tackle the issue to get things rolling right for you. With that in mind, let's start tackling this fresh understanding there are issues to solve. As Doc stated, there are many possibilities. I know you didn't intend to insult, but wording and mindset shouldn't seem like it's sounding like the badass rom that works without a hitch every version for my green ass is to blame. I don't know much, but I know we can figure the issues. Am happy to rap via phone to expedite, or will keep an eye on the posting to help resolve your battery issues. I would recommend following the op to a tee to reset, reset your pewter with the battery out prior to, not debloat initially, and maybe even use tools to double check your charger and new battery. Will send extra stock battery if you pay postage, and help troubleshoot. Pardon the uber long post yall.
I see something here about using Android System Info.
Good app, I use it myself.
For this sort of problem - if you haven't snagged it already - Gsam Battery Monitor.
It's top notch and it's free and it's my go-to tool for all battery issues.
Discharging faster than charging can be any combination of -
  • Phone unable to sleep properly
    • Caused by wakelocks or runaway services
    • Gsam lower left corner - it's a Hoover, shows what's sucking what.
    • Next screen, the title at the top - it's a menu - snoop around some.
  • Rouge processes that have gone haywire
  • Wifi signal issues
    • While I'm at it, if you're on wifi while this is going down, snag Wifi Analyzer, also free, and make sure that you're not on a shared channel with the same default router name as your neighbor.
    • Network stack changes from rom to rom - yeah - that can expose a problem elsewhere and fool you as to the cause.
    • Fix those at the router.
  • 3G signal issues
    • Gsam has a nice graph, works in landscape.
    • How's that 3G signal - nice and steady, medium or better, or jumping up and down?
    • When your screen is off, is it showing the device asleep?
There's a few things to get you started, I think they'll serve you well.
Unless - it's a hardware problem.
In which case, it'll still serve you well, because if it's nothing listed above showing up, then something wonky is happening with hardware or rom/hardware combo.
That happens. Just is what it is.
Hope this helps! :)
  • 3G signal issues
Hope this helps! :)
Great info, thank you sir......:)
Indeed. Thank you sir. Great info. That took some time to write up. I'm at 85% now on a discharge. I've been playing a movie with the screen brightness on high. Its actually discharging seemingly well. I will take your apk recommendations and do some testing with them. I'll report back upon testing and full discharge and recharge. Thanks again everybody.
Not sure if you wanna, but getting that ace battery next week and seriously will send what will be xtra stock battery if you want it and pay for shipping if that helps you.. Not trying to be from the redundant department of redundancy. Anyway, glad solutions are in the works.
