Titchener17
Hope you feel better. You are a kind trooper
Oh, and I'm sick as a dog today and thinking fuzzy when I talk so make me repeat anything that doesn't make sense.
I said a day before, I just meant - some time, like - an hour or so.![]()
That wifi analyzer mentioned worked great. Had no idea neighbors settings and mine were interferring like that. Was able to dial in the exact channel after testing to set jetpack to, and no more bandwidth interference, now all speeds tested are way faster too after testing. Really neat, was oblivious to that before reading EarlyMon suggestion here in methodically determining a solution to battery drain issue. Glad it's in the process of getting resolved for you man, and am gonna rehash to learn from all sensei support here. Thanks for the clarification G. Hey could you clear up what I should set roaming guard at. Can interpret what it means, whether it contradicts enabling roaming data and voice, is it protection or what? Like in a valley, think may need roaming to make sure messages go out and everything works being here in a spot that is tough on reception? Sorry if off topic, but maybe it isn't as far as looking for signal component. Or is the guard protection like a firewall when roaming? Anyway glad battery is getting resolved proper.
