FLASH INSTRUCTIONS
very important make a nandroid always!!
If you choose not to use this Gapps or follow instructions then you will need to ask yourself why isn't this or that working right!
1. Make sure your using latest recovery SmelkusMod Recomended
2. I recommend wiping data/factory reset (especially if on another rom) x3 to be safe!
3. Flash Rom
4. Flash stock gapps zip
5. Reboot go thru setup sign in to google account!
6. Get thru setup. (If you wanna let market restore your apps wait but try not to open market)
7. If you opened market before rebooting go into settings>apps>all apps and uninstall market updates!
8. Reboot back into recovery and flash Black_ICE-gapps zip
Step 4 is flash a stock gapps.
Step 8 is to flash the black ice gapps.
I'm just unable to find a stock gapps
