Root Blkkangbluecircbat theme for Fission 2.1 gone final (?)
@faber78
I figured out how to change status bar colors and a few other colors concerning the "Verizon Wireless" (which I changed to "iPhone Killer" :p) color. I remember you wanting to change the colors at some point.
I don't know if you've figured it out or not, but I can link you to the threads that helped me out.
I still can't find the .xml that changes the color for the settings menu....do you know which one it is. It's hard figuring out which .xml is for what :p
Check out what I've done so far, the first one has the clock in the status bar, the second one does not:
Also the info that runs across the status bar when you install an app or connect to usb, etc. is blue.
that is awesome :D
i would love a link on how to do that, i have no clue....
Will this work with Fission 2.2.1 too?
if you mean this theme, i have no clue....im still running 2.1
that is awesome :D
I'd like to know too. I read something about needed a hex editor to decode the xml files. That didn't sound too fun but I just have not had the time to investigate further.
all i can get is; "cant access jar file"
Did you rename the colorChangev3.zip correctly to .jar?
What services.jar file are you using? If you send me your services.jar I can test it out to make sure it's working correctly.
Did you check the last link I gave you....if you follow those steps it should work.
I don't know if you are using PowerCmd? I use it, it works really well.
renamed without the zip/ services from framework/tried pwrcommand as well....
appr. the come back.
should be my services file
theme.zip
must be doing something wrong....
theme.zip
I think your issue is you don't have java installed. Go here and download and install it:
Download Java for Windows Firefox
EDIT:
It's weird, your sevices.jar requires another .jar file to work correctly, it needs baksmali-0.93.jar.
Try using the ApeX NexTheme services.jar, I think that's what I used.
have java
gotta be something im doing wrong. changing the verizon name was gravy.
downloaded the v3, removed zip (simply renamed without .zip) and dropped on c drive
removed services (tried w/my theme and the one you recommended) and put in theme folder; zip w/no compression. drop on c drive
tried both stock and your recommended command and keep getting the error.
C:\java -Xmx512M -jar colorChangev3.jar theme.zip network=FF0000FF date=FF0000FF clock=FF0000FF
ill keep working on it, has to be an error on my part.
let me know if you think of anything im screwing up....
have java
I still think the issue is that the correct version of java's not installed. I had java installed too, but when I installed the java I linked you to it started working. I was helping out someone on xda forums too and it didn't work for him either until he installed the linked java.
EDIT:
Just try installing the java I linked and afterward type: java -jar colorChangev3.jar
IF you get a bunch of text with commands/directions then it's working.
clean uninstall of java, reinstall per your link, command java -jar colorChangev3.jar"
processor runs like its thinking about doing somehting, then same error.
I didn't uninstall the java I had installed, I just applied the linked java over it. I don't think it would make a difference to remove the java you had installed first then apply the new one.
Try this theme.zip:
theme.zip - 4shared.com - online file sharing and storage - download
EDIT:
Wait nevermind.........you have to get colorChangev3.jar working first.
How did you rename the colorChange zip file.........is it colorChangev3.jar or colorChange.jar......the first time I renamed it I mistakenly renamed it to colorChange.jar instead of colorChangev3.jar
I am using this one.....don't rename it, just extract it from the zip.
colorChangev3.zip
Should look like this after the command (my files are not in the root of C: but it should still work; I just tried with all files in C root and it works):
maybe i dont have it installed in javas "path"?
Do you have android-sdk installed with the path in system variables? You should try adding Java to system variable path and see what happens........I had Java in variables path from when I installed the android-sdk.
So it was the path issue?
no, it was me being a dumbass....it was starting out in c:user/mini> and id put C: for drive but i needed to drop in C:user\mini.
tried to change to just C: but didnt know how.
though i still couldnt get it from stock command prompt at C:\ when dropped in C:.
for some reason it worked through the other power command in the location it was pointing at.
learning experience for me....i sure appreciate the help....:)
Cool, glad you got it working.
You could have typed "cd C:\" (no quotations of course) to get to C:\ or just "cd.." a few times until you reached root......don't know if you tried either of these options.
look at that....rock on....learning experience....i really appreciate the help.
something i needed to get my feet wet with.....:)
Always glad to help.
If you figure out which .xml file changes the color on the settings menu let me know :p
