Root Bloatware help
icrazy2u
So I've seen a couple ways to remove bloatware, just wondering has anyone used the Titanium Backup way to remove the bloatware?
i did it that way, no problems here. took two minutes literally to remove the 7-8 apps i did not want on my phone. :)
May you tell me the ones that you removed. I'm scared I might delete one I need even though I already a nandroid backup.
Just downloaded Titanium Backup..... how does one use this method to get rid of bloatware?
When I select an app from the list, lets say Amazon MP3, I get a box that pops up that gives me an option to un-install and then a bit under that an option to delete. Which one do I select?
Uninstall.
FYI... Amazon MP3 is the one app that Titanium seems to have a problem with removing, and it seems to be pretty 50-50 on it working. For instance, it wouldn't remove on mine but it removed on my fianc
One last question, if I deleted a app that I needed and can't find it, couldn't I just recover the whole Rom using nandroid and have them again? I'm just going to delete the ones I don't want and hope I don't need them again.
Another option to consider is to perhaps relocate those apps rather than removing them. Why? If you (or some app you may d/l in the future) may need or require elements of them, you'll still have them. Easy step-by-step found here: http://http://www.jonamerica.com/technology/remove-bloatware-from-htc-droid-incredible-2-2/
That link has one to many "http://'s" in front of it. here it is:
Remove bloatware from HTC Droid Incredible 2.2 - Technology - Jonamerica.com
If you don't want to delete you can just move them to a diffrent folder. I used root explorer just in case if I ever want to go back and use one.
