yeah, mine does too. i tried to switch to speaker while listening to a voicemail, and didnt realize that i had to let it play to the end before i can switch.
It's on xda root for one sv
My speaker doesn't work after I use the stock visual voicemail, I have to do a full shutdown for it to work again. All my sounds come from the earpiece afterwards.
A bit of a pain, anyone else having this problem?
i updated the voicemail app, if that makes a difference.
Oh boy!!!, are you getting ads after the update of the voice-mail app???
not that i noticed
Kool, was afraid to upgrade cuz I'd upgraded mine on the ZTE sequent and the freaking ads appeared at the bottom.
I didn't realize it was gone until last night when I searched play store and net and couldn't find it any were.... Have 5 versions saved on my sd card...I've been using is since the release of the prevail... Its priceless, must have in my opinion!
I thought i was the must have in this section lol.
I feel so special
Removing contacts will cause the dialer to fc. You can remove MMS.apk and a few other stock HTC apps but not contacts, dialer, and on certain ROMs removing email.apk will cause camera.apk to fc. Any system apps removed need to be replaced in the system partition. Hope that answers any questions you might have.
No adds on my phone... Old version of adfree I use.. http://db.tt/xqLvEdgP
