Help Bluetooth auto-connect
If I turn the phone's bluetooth on first and then the headset, it connects automatically. But if I have my bluetooth headphone on and then turn on bluetooth on the GNote, nothing happens. Is it supposed to work like that? Did I skip a step when I paired the device to the GNote. All I did was turn on the device (while bluetooth was on on the GNote) and once the device showed up on the phone I tapped the device name and viola.
No idea, mine works either way.
What headset you using?
I had tested this with 2 differnt Plantronics and a Jawbone with no issues.
The latest samsung devices do not properly autoconnect if bluetooth is toggled off on the phone. Re-pairing is neccessary
The only solution is to reboot or leave bt on.
