Root Blur Dialer, Liberty ROM
In Liberty dialer is : phone.apk
You can delete it with Root Explorer or Titanium backup or using Terminal Emulator. Whichever way you more comfortable with. In blur ROMs dialer is dialer.apk, but I'm not sure if it will work on blurless ROM, as some of blur apps require some other blur stuff. Things like gallery or camera can be installed for sure, I don't know if anybody tried install dialer.
I think the dialer is one of those things that can't just be substituted in/out. It requires a different framework in order to run properly.
I was hoping that wasn't the case, I know you can get a couple different ones from the market though. I couldn't find the phone.apk in titanium, before I started this thread I found that in the rom and tried to find it to uninstall it but no luck. The blur camera and dialer is all the blur I want
You can do blur alarm and blur camera easily, but the blur dialer is not going to work.
If you want a similar ROM to Liberty, then go with Fusion by AngDroid (maker of Fisson ROM). He made some modifications to that ROM so the blur dialer would work.
I tried fission but it was similar in speed to ApeX so I went back to that. Liberty is way faster than any thing else I've flashed
The dialer/phone is one of my biggest "complaints" about Liberty (and it even isn't that big of a deal, haha).
I like the Gingerbread Vanilla dialer... being able to search contacts from the dialer screen via T9-like searching is really great..
I solve the problem by going going back to dialer one. I need smart dial. I do, however, love this Liberty. More viable and stable roms for us means more fun for us!
Another sweet dialer is TouchPal Smart Dialer (free in market)... I love it... just a nicer look and works great... don't worry if the pictures show it in some asian language.. it works in english just fine on my phone.
I just downloaded that last night along with several others. I tried it just now because of your recommendation and I think I like it the best, but the smart dial feature isn't as good as blur. When I type in my fiancee's number it brings her number up but no name and a? even though she's in my contacts.
