dennis8492
Getting your msl code
-first download alogcat from playstore
- then Set a filter with the word code
- next open your dial pad and enter ##3282# and simply view any thing
- now return to alogcat and your msl code shows in red.
Simple right? Also easy way of changing proxy and ip's.
Here's MY QUESTION. WHAT OTHER TRICK OR CHANGE CAN BE MADE IN THIS MENU TO INHANCE THE WARP AND ITS PERFORMANCE??
... with it you can add custom shortcuts to activities and there is quite a few hidden settings menu that can be accessed through it...
