Root [Boost Mobile] B10 Based Rom
Where can I get that XT9 keyboard? I can't find it anywhere. Tried to install the apk to another rom, but as I expected, it failed :)
screenshots:(background is from Next Launcher JellyBean Theme, Holo Locker is ICS Themed)
Holo Locker
Holo Launcher
with Next Launcher (not included)
Themed Settings menu
Hi Lil
i cant send mms?
do you know if there is a fix for it that you could help me with?
Sometimes the Boost network just doesnt want to work for us properly, Try a fix permissions and clear both caches in your recovery program. :)
I have the same problem once in a while no matter what rom I use:mad:
Also do a update profile, prl.:)
I have had mms messages just sit for hours until I long press the message, hit edit, then re-send.:)
  • Like
Reactions: Doc
Thanks Lil for getting back to me with an answer so quickly.I seem to be having this mms issue with this rom only no mms with any other custom rom but i am going to follow your advice and see if i can get it to work again thank you very much for your help.
Your Welcome, hope it works!!:)
