install voltage control, set it how you want it, save to init.d startup script, that will generate a script in init.d (can't recall exactly but it will be something like 99voltage)
to include that in your ROM, just add the proper permissions in the install updater script for the init.d folder and script (you can look at any of the other roms that have overclock for those lines)
Saving as init.d script fails ?
I only used it for a few days, till NoobVIII.II came out.
I will look on my sd card and see if I may have one or two but I dont think so,
