Root [Boost Mobile] BootLoader/Warp Drive
I thought i was running 2.1 and when i check my phone i was still on 2.0 and was having wifi issues. So i tried to install 2.1 and now im stuck on the MRbobo android screen.....been like that for a good 10min and im afraid it may have messed something up. how did you get yours to work?
I kept trying for recovery, once I had that I did several factory data resets in a row, wiped the sd card and transfered CTMod and noobV1 over as well as CWM. Reflashed CWM
I was using TWRP, Did several more factory data resets , clear cache, dalvik, 3-4-5 times, Finally flashed CTMod because, I knew it was a small simple powerful rom, and if I could get one to flash, then this was my best chance.
And, it worked. Ran that for a few days, then did all the above, Factory data, clear cache, etc, And flashed my old favorite noobVI. As of right now, the phone is solid as a rock, except for the random MMS issue. But that's a network prob, IMHO.:)
Do you remember how you got recovery to come up?? I know you were getting ideas from Shin to connect to the computer.
If I remember correctly you were stuck in a loop and kept pulling the battery since it wouldn't even boot into recovery. This is what I'm afraid of. I never tried to reflash after re-downloading b/c I don't want to get stuck in a boot loop.
So the key is getting into recovery then you can flash anything to override what ever is screwed up.
Thanks Lil Bit.....I was able to get into recovery and Flash back to NoobVI.....running great again:)
Whew!!! Good!! I got to tipsy to try the software shin linked to, put the battery back in and tried for recovery one last time and, Viola!! Team Win came up!! :D
I'm back to using cwm because I'm used to it, and it seems better, for me at least.:)
lol too tipsy:rolleyes:.....party girl huh ;)....Yea i never did mind using the volume rocker.
