Ok wiat system? linux or windows, I have both.
i'm guessing you don't have the android debug bridge installed, in which case you would need that first. there is plenty of documentation on how to set that up. But your going to need that first and foremost. Or if you have warp drive you can open cmd prompt.
CD <location of the warp drive folder>
ex CD C:/Users/Shinru2004/Desktop/Warp-Drive/
then you can use the adb commands once you inside the folder
try adb devices a few times while its booting if it comes up with your device then you have a connection. I would suggest trying ti while booting and while trying to access the recovery, one or the other SHOULD allow access.
ex of adb devices command
this is on my linux box but the theory is the same
Shinru2004@ubuntu: adb devices
