MrBobo
Android Expert
Overview:
Rooting is now a one step process for the original Boost Mobile Warp!!! This method works with the B10 update that was pushed out between december 2012 and february 2013. Download one of the two zips below and install update from stock recovery. This will give you Root, install a custom recovery of your choice, install the data fix, and make custom recovery stick from that one single step. I have personally tested by going back to stock using the ZTE software update tool and trying it multiple times. Note, if you have Public Mobile this method will not work, please see post two and try the other methods, please do not post to this thread concerning Public Mobile or other carrier versions of the Warp.
Detailed Instructions:
Both recoveries work great, personally the touch recovery is my favorite, I extend very special thanks to Hroark13 over on xda for porting this recover to the warp and Team Win for coming up it in the first place, please drop by over on xda and give Hroark thanks for bring us TWRP, if you don't know he was legendary over here for getting kernels going etc for us and we would be way further behind where we are today.
Special thanks to these three for finding this method:
wilm804xx
Downthemachine
Jetx2x
- Download a zip with the custom recovery of your choice, and save to sd card:
- EasyRoot TWRP (Team Win Touch Recovery)
- EasyRoot CWM (ClockWorkMod)
- With phone completely shut down press and hold the power button and volume up button at the same time until you see the android system recovery
- Choose Apply update from sd card (use the volume keys to go up and down and the camera button to select)
- Choose EasyRootCWM.zip or EasyRootTWRP.zip and hit the camera button to run
- Reboot and enjoy root/custom recovery!
wilm804xx
Downthemachine
Jetx2x
