Root [Boost Mobile] $hEvRoN Theme {Updated 4/09/12}
chevanlol360
Android Expert
Hello everyone i would like to introduce my first theme that i created for the Samsung Transform Ultra the "$hEvRoN theme". Lucky for you all i was wondering around the zte warp section of the forums and found that there was no ROM or theme yet released so i thought why not bring the $hEvRoN theme to the warp.
What it looks like on the ZTE Warp.
Notification bar shot000001a.jpg Over scroll color shot000002a.jpg lockscreen shot000004e.jpg Boot animation 0054.png
List of more things changed
* Signal bars themed NEW!!!!
* Battery Icon
* Boot animation
* overscroll
* Status Bar Background Color
* Window Animation
* Popup Color
* Header
* Volume Bar Color
* Font changed to ICS Font
* Downloading Bar color
* Status Bar Icons
* Lockscreen
* & much more has been changed
What's new in version 4.0
■ Signal bars are themed and now have support for the Shinjitsu ROM and stock ROM
Make a backup right now
Downloads For version 4.0:
ShEvRoN Theme for Shintjitsu ROM
ShEvRoN Theme for Stock ROM
DO NOT unzip the file please place it on your SD Card
How to install with CWM
1. Boot into CWM.
2. Wipe cache & dalvik-cache "to find wipe dalvik cache please go to advance in the main menu of CWM"
3. Turn off your phone
4. boot into CWM again
5. choose "install zip from sdcard"
6. choose "choose zip from sdcard"
7. locate to where you placed the zip file on your SD card
8. confirm "YES"
9. wait for script to finish
8. reboot phone
There you go you are now running the first theme for the ZTE Warp the $hEvRoN theme enjoy.
to SnakeX, sweet mods. made a couple myself, ill try to get them up here as well... :D cant get the power options on status bar pull down though
Looks good. Can't wait wait to try it out. Pardon my noobness, but is it a theme for the stock launcher or something like Go or ADW, or is it a modded stock launcher?
Cool boot animation. Well done but it won't get past the boot screen.
edit: i changed the boot animation and it started up just fine. i really like the changes you've made. cheers mate.
thats weird androidxd didnt have that problem hmmmm. turn off the phone boot into cwm reflash the zip then reboot the phone leave it for 5 mins dont touch it. see if that helps
Download link has been pullled causing bootloops great-__-
restore to a backup if you already had download the link and installed it
looks like its a minor problem causing the bootloops it will be fixed and released "again" lol tomorrow sorry for the trouble guys
now how can i fix it the bootloop ...
i dont have a a backup or microsd adapter to transfer the new theme or a backup
It was written in the instructions to do a backup first why didnt you? And do you have another android device in the house?
i did backup but iwas using the first cmw beta and the restore came up with a an error
and no i dont have another android device
but i can go into bootloader where you install the cmw soo if i can only transfer the new theme to microsd card or install a nandroid rom from there?
damn your in a pretty tight spot right now, lucky for you i know my way around cwm.
boot into cwm plug in your device to your pc go to mount storage in the cwm menu then select usb storage your sd card should be recognize by your computer place the theme on there and flash it.
funny i installed the new cmw and the usb mount doesnt work
i think im going to buy a microsd adapter sooo
thanks anyways
