Root [Boost Mobile] MMs issue's widespread
I tried the flash and had no issues with the file. I still cant send or recieve a MMS. I have tried cache wipes, flashed non-OC kernel, and now this packet
Could you post on how to do that? :D
As an FYI for us:confused:
theres a easier way if your using holo launcher(noob rom and shins both run holo) just long press screen go to shortcut click activities scroll down untill you see setting click setting then scroll down and keep your eye out you will see proxy setting click it that will put a short cut to your proxy on your home page click on that which will be on your home page and hit clear then save restart phone proxy all gone;}
Hmmm, Thanks for the info;) My mms is still down to, have no clue??:mad:
Kinda peeved about it too:mad:
I'm still sayin it;s boost network :mad:
I'm not sure it's the boost network because my brother has the Samsung Transform Ultra and he still sends me random MMS pics. I'll try and verify it tomorrow though. My other brother is on sprint and has no issues either, but I dont know just how different the two are.
Edit: I recieve the MMS message, but the file doesnt download*
The strange thing is that I was not having mms problems (I'm with public mobile) and that this actually made it smoother on my end... I was having issues with mms when sending to one carrier...it would take hours before the recipient would receive it and now it's down to ten minutes....this did do some good...I'm gonna include this apns-conf.xml in the next version of my beta...
Which one helped?
Makes sense, I think Public Mobile uses Sprints network too.
Everything is working perfectly today!! I have changed nothing, flashed nothing, no changes at all,
I sent pics with the camera set to normal, fine, super fine. Different picture sizes also. I knew it was Boost!!! I knew it!!!!
My wife sent one yesterday, didn't get it til later when she sent a text. Weird
Where are you located at? Cause I live on the central coast of Cali and am not having any issues with MMS
All that was when I was in Jersey:)
I moved to Columbus Ohio a month
or so ago. I live on the OSU campus
and have a great signal here, no mms
probs at all so far!!:D
I contacted boost when mine started to do this about a month ago, after about a hr on the phone with tech support I talked to a tier 3 tech and I was told they were having issues, so I don't think its any specific rom its on there end.
