D
Deleted User
Guest
I recently noticed that my phone does not vibrate at all for anything, ie, calls, notifications, alarm, etc. I follow this forum daily I tend to try out any mods, roms, tweaks, etc that pop up on here that could enhance my phone and knowledge. Currently running Shinjitsu 1.5b, tried WP7, and $hevron. Ran hroark's bootwithadbenabled.zip like he suggested to someone else with a vibrating issuse. I have a lot of apps installed so I have no idea which if any if those would be it. As I am writing this it just dawned on me that it is most likely a hardware issue since the problem exists on all roms including stock, and the phone gets wiped before flashing. It also exists before restoring my apps so that makes it being an software issue unlikely. So... I guess i'm asking if anyone has any other way for me to be sure it is a hardware fault and not some missing file(s), config or setting.
