Root [Boost Mobile] Need Help Please
My warp is stuck at a boot loop and i dont have a backup i forgot to do one, i tried to wipe it but nothing is working. I can still access cwm but thats it please someone help me.
Get one of woodstocks nandroid backups just search for woodstock and on his profile just view all threads and look for the nandroid thread
Go into the file click the md5 folder properties and write down the.date and time change the folder name to the date and time like 2012-05-09.xx.xx.xx but make it date and time of the md5
Im so sorry but i dont understand what MD5 is and what file you mean. Is it the ROM file? I truly thank you for helping me, i could not be doing this without your help
Okay when you see the backup file (the file your restoring) open it youll see the md5 file long press it and choose properties and look at the date and time and then whatever the name of the file is (ex. NANDROID BACKUP) change it to the date and time the md5 is in the exact.order i showed
Ok i see the file now and the name of the folder is 2012-01-27.08.04.07 , i understand that part, now the only part i dont understand is the date change part. All i see when i click properties on the MD5 file is date modified which is 5/9/2012 8:55 PM
Im sorry for causing you trouble, im just so nervous im like forgetting everything
Wait, do you mean to change the name of the md5 file "nandroid" in the properties to the date the folder is with the time?
Okay the.md5 modified date change it to 2012-05-09.8.55.(whatever seconds) then run cwm nd restore and BOOM it should work if not ill upload a stock rom that all you have to do is press install zip from sd
Are you changing the.folder name or are you tryong to edit the md5??
Okay here let me take it step by step the.FOLDER that the md5 is in is named whatever date it was created the md5 was modified tonight therefor the folder name has to match the md5 modified time get it? So your md5 says 2012-05-09.08.55.XX (replace the XX with the numbers in the seconds area) just rename the folder that date and time the md5 was modified as stated above
Dont try editing the md5 just rename.the folder the time the md5 shows as modified
Ill post screen shots to show you
Ok thanks so much, i know i sound really dumb, but im just really nervous lol. I changed the folder name to the MD5 modified time, but i dont get the seconds, they arent shown on the MD5 properties ".XX" i put a random number "14" and tried and it still gave me the mismatch thing
Okay since apparently i dont have root access >:| just tell me exacltly what the md5 modified time says ill figure this out for you
