Root [Boost Mobile] Need Help Please
Yeah just download the file then install from zip make sure you backup whatever you want itll wipe everything out so make a backup
Dont give up im going to upload for tech support purposes my names dakotah ill send you a link for a stock b08c
Thanks so much, the thing i fear is that nothing seems to work now, i wiped all data, i installed 2 roms and they give me errors and the backups have dissappeared so im really lost, but i really thank you
Okay those are usually the two you need to clear before installing anything
And dont worry ill be here until your phones running good :) hate to see another warp user having trouble
Okay so may i ask what cause the bootloop?
Ok i tried the clearing and it still gives me a loop.
Basically i rooted the phone and worked great. I wanted to install the Shevron theme so i installed it through CWM normally but forgot to do a backup. Once my phone restarted, it just gave me the boost logo and kept looping, i havent really done anything with my phone before, it was running perfectly
Have you successfully flashed one of Woodstock's roms?
Sent from my N860 using Tapatalk 2 Beta-5
Okay yeah honest mistake no worries im going to give you some advice kid whenever you go to install something MAKE A BACKUP AND.CLEAR.CACHE AND DALVIK!!! If not you can get problems like this but hey dont worry i cant even count how many time i looped my phone haha so no worries ill get.you through now that there clear try reinstalling my rom see.if it works if not ill be sending you a stock rooted ROM
Ok thanks so much. The only thing is that since none of the roms and backups ive installed have worked so thats what worries me
Okay im going to send you the contents of a b08 its rooted AND itll allow you to install shinjitsu it doesnt work on b08c your going to have to put them into a.folder ill give you the.time the folder has to be named too
