Root [Boost Mobile] Need Help Please
Ok thanks so much. The only thing is that since none of the roms and backups ive installed have worked so thats what worries me
Its probably because somethin was wrong with the file like i said im sending you the.contents.of a backup b08 you have to put them into a.folder and.name the.folder the date i give and YOU NEED TO CHECK THE MD5 and make sure its the same if not i want you to send me.the date and time it says ALL OF IT
Ok thanks! And my name is andre
Well they will but you would have to pay since you rooted and that.voids the waarenty
True :(, if its that way then i might wait for the evo design if it comes out soon but whatever, i dont want to think about that right now lol, and trust me, im not getting anywhere near my phone anymore after today lol
Haha well dont say that like i said if your unsure of the results of what youz do make a backup then do it trust me ive gone through probably like 200 restores because of bootloops haha trial and error im workong to be a dev so i know how to fix. Most problems with this phone because ive experienced so many screw ups haha
Yeah lol, i wont forget that XD, right now i miss my phone more than ever lol
Haha and i suggest staying with the warp for a while we just made a breakthrough with an open source kernel so this phones only goong to get better :) itll take a while before the evo does
The filename of the backup can't have any spaces in it or you will get md5 mismatch error when you try to restore... even if the backup is perfect
Sent from my N860 using Tapatalk 2 Beta-5
The name of the backup was "nandroid.md5" so i dont think that was the problem. And yeah i know i want to see the Warp overclocked my self, only thing i dont like about the phone is the viewing angles on the screen which bother me alot for some reason, ill keep it if i can.
I had to restore to a backup of shinjitsu because I was stuck in a boot loop and I needed to use the phone... I'm going to reflash it in a lil bit though... everything works perfectly so far except for the boot issues
Yeah me and shinru are trying to figure that problem out
Well my rom offers overclocking and damn stable too you can go ahead and try it again just make sure cache is clear and dalvik ill even send you a fresh link :)
http://db.tt/yzCxwTjP
Make sure to clear and factory reset
I tried to do it again but same problem happens, it doesent want to install, i press install and takes less than a second and i get no message, i start the phone and i get a bootloop and thanks lol, your rom looks cool!
And are you putting the zip on your sd card?? That might be the problem in order to install the zip it HAS to be on the sd and if your phone wont boot you wont be able to put it on so find something you can put the downloaded zip on the sd with old phone adapter anything
Make sure all of the necessary files are grouped into the same folder... then make sure you place the folder in /clockworkmod/backups... then make sure the filename doesn't have any spaces because like I said it will cause it not to work
Yeah, im putting the zip file on the SD card and it gets detected by CWM but for some reason it cant install, ive rooted my tab before and ive overclocked it and everything but i guess this phone gives me bad luck lol
Okay well the backup system is uploading now might be a bit because its big but when you get it check the md5 and.make sure it.matches.the.time of the. Folder if not send me the md5 time and ill give you the proper time to change the folder to then put it in clockworkmod/backups and it should work
