Root [Boost Mobile] Project Yoshi
I had the same problem a while back... I had to keep enabling/disabling and rebooting to get it back working... dont know the exact cause of this... clearing cache/dalvik didnt even help... wiping data probably will do it but I dont know for sure
Sent from my N860 using Tapatalk 2 Beta-5
Yup, They are enabled:D
No I didnt do that (uwd?).....was hoping I didnt have too lol Ive been flashing and reflashing for like the past few weeks. Was hoping to settle into one of the ROMS for a little while. Any thoughts on what the actual root cause could be? Does anyone else have that issue on Yoshi?
Ultimate warp drive
I understand it's a VERY common problem for... I'm pretty sure... Every single rom for the warp at sometime or another. Users love dark backgrounds but it's tricky to pull off
So after Flashing a little after release Ive no lonber been able to get the screen lock sound or Audible selections to work on my phone. Even after flashing a new ROM. Any have any thoughts?
anyone else have any other Ideas why this might happen?
not necessarily a dark background...just a dark green may show up over the white
Can someone please explain how to fix invisible text issue...its the same way as warp cream sandwich
thats a theming issue, they have to update it to fix it. this happened before on IconRom but it was fixed quickly.
I have invisible text when im using google voice application to text and i use that app all the time its a huge problem wish this would get fixed asap
I feel this ROM was not ready it needs some fixes if you still have the zips I suggest you keep them please do not hand them out :)
Links pulled from OP link will be back up in a couple days time
Thanks for understanding :)
It's a good decision to keep from distributing the problem to more people. When the text problem is fixed, new users will be happy with the ROM and give it much better reviews. In order to be part of the solution, please let me know if I can test the fixes before release. Again, thanks for making a tough decision. :) :) :)
I have been doing research, and I found a quick fix for the text issue. I am using it now and all my text problems are over.
Could I have the wallpaper on this rom. The fix removed it. as soon as i transfer the zip i will upload it to my dropbox and and place link. also, after trial and era- i got touchpal keyboard to work
