Root [Boost Mobile] RapTurE V1.0.0
Status
Not open for further replies.
StarScream2109
Extreme Android User
Testing is going on but there is going to be an update to it then testing again NOT TAKING ANYMORE TESTERS sorry guys itll be out soon i promise
I AM NOT RESPONSIBLE FOR DATA LOSS OR DAMAGES! Youve been informed testers
Okay heres some details to this ROM
1) BLOATWARE removed
2) no stock email besides gmail
3) 3 launchers to choose from
4) B08C is what it runs off of so only use that unless its tested and proved to work on earlier builds
5)this first post will be edited with everything that the ROM has and does not have when its almost done so keep checking in for upates and the such!
6) im putting a lot of time in this and getting some help from chev and shinru and mind you this is the FIRST version and the version gets higher the better it will be
7) coming along good getting supercharged and possibly CRT animations once those are done ill theme EVERYTHING (with help in some parts) and then the beta tests will be done
And thats all im saying at this point in time its still being developed but i promise it will be a strong ROM and im hoping you guys will enjoy it
UPDATE!!! You have until tonight to throw me ideas and suggestions for this ROM after that i will not be editing or adding any apps i will only be themeing and tweaking!
Yes init.d support will be there im also hoping for overclocking and supercharging too im really hoping this ROM will be good but i will not take all credit for it chevanlol is helping me out A LOT!
Not a problem. What type of browser are you intending on using? I'd like to talk to you about a boot animation. I wanna install one but don't know the steps to change the ani and sound.
boot animation: /system/media/bootanimation.zip
boot animation sound: /system/media/audio/UI/ (forgot if its bootsound.mp3 or Bootsound.mp3, should be one of those 2)
Its Bootsound.mp3
Sent from my N860 using Tapatalk 2 Beta-5
Well what do you have in mind? And if you want pm me and ill teach you how and about the browser im a fan of dolphin so thats going to be system
the bootanimation.zip yes. You must do it specifically though. Try googling bootanimation.zip tutorial
By no stock email you do you mean we will not be able to add other email accounts,I.e. corporate?
By no stock email i mean you will have to install an email app to your needs and it will be deodexed and there will be plenty of tweaks for performance and other odds and ends and i even have a surprise for whoever decides to run it when its released
Can you make it a zip file that works in CWM and not a back up to restore because the m5dismatch is a b#!
Status
