StarScream2109
Extreme Android User
Thank you for supporting it makes me all fuzzy inside or that might be the cotton candy i just ate
Okay my phone is def messing with me >:| haha
It's not letting me install TB from zip. (google play is ok) and if I restore an apk from TB the phone will freeze. After I hit the reset button and reboot I loose the app I restored, TB and google play.
Please help. Installed as instructed and the green android stays on when reported. Stayed on for 15 minutes went back to old Rom. Coming from win 7 rom
Yeah >:| stupid superuser!!!
Yeah, after your next flash. Do not update the binary in Superuser and just use SuperSU. It will update the binary through it and bypass Superuser. You will still have root and less problems. :thumbup:
Did everything except factory reset. Even reinstalled stock Rom with same results. Will try the factory rest as well
Tried to restore all missing apps with TB and freaked the phone out lol.
Went into CWM to do a factory reset and got this
https://www.dropbox.com/s/bwkkul2h10bpjvq/20120509204809.jpg
might be I just freaked out my sd card
Very nice Rom, I really like the boot animation. Is there a way for me to use Live Wallpapers on your rom?
I turned my phone off about 30 min ago. Turned it on and been getting an forever lasting boot loop. I'm trying to be patient.
