Stlouizsin
Had to go to no overclock kernel but otherwise it's running great
Thanks. I flashed the 7_n
I decided.. What the hey.. Let me check this ROM out and see what it has.. Today I was coming back from a job about 2 hours away from my house and the phone froze.. Then was stuck in a bootloop. I ended up having to fix permissions, Clear cache, and Ultimately do a factory reset.. Which did nothing but wipe my apps and everything else. I get back home finally and get everything set back up again.. What do ya know?? Freeze and bootloop. I'm not entirely sure what the issue is, but it is frustrating. Is there a fix for this bootloop and crash, or what?
my guess is it's the kernel, see my post a couple posts up on how to change that... I had to change that to hroark's kernel to make it stable for my phone, other than that I have only seen what looks like a bootloop (boot animation goes a few times) if I wipe dalvik and reboot, but eventually it does load up... I also saw something like a boot loop when I let my phone run out of battery last night and then tried to start it again, but I think when it shuts down like that it's like wiping the dalvik so it will need to cycle through the boot animation a few times as it reloads.
Apollo did good. I expected less apps n such since he said it would be simple and the people's ROM and I was the one pressuring him. I wont deny it because I was entirely too eager.. And drunk. I half ass apologized but I will do so again. APOLLO i am sorry for being a jerk.
Now with that said.. Do we solely think the problem is the kernel or is it the kernel and A2SD? I'm not too tech savvy but I am getting a handle on some things.
So, i wanted to try the rom, but I made my own theme for it, uploaded your files and everything, but then it gets stuck in a bootloop....anyone know how to fix this? I uploaded the framework and the system so im not sure what the problem is...maybe if i make a theme WITHOUT modding the bootscreen ? anyway i would like to run this rom but with diff colors and the icons i prefer...so...brainstorm here, why is UOT Kitchen made themes w. uploaded files causing it to bootloop?
The kernel is a problem for sone but the majority is a2sd also guys i have sone exciting newscrt effects will be added thanks to chevanlol
yeah I immediately changed the overclock to Max of...1.2 I believe... had no issues whatsoever until I installed a theme.
I turned off the boot animation and it stopped the boot loop. It does take a long time to boot up. Seen it take as long as a minute.
How do i go about doing this? TB?
It doesnt help that there seems to be an issue with the animation im not going to get rid of it though >:|
It just gives rapture that feel![]()
I didn't turn it off because of the loop really. I turned it off so it didn't bother anyone at work. But, I noticed after turning it off my phone no longer freezes from time to time on restarts.
