Should it get shortened??? What do you guys think?
I would say i need to remove more of the frames to make it run smoother which was something i planned on doing to begin with
i have a question..i loose service when i got the wifi conected..i was wondering if theres a fix for that? im using RapTure..i have a pic just incase u need me to send it so u could see..im using a B08c..thank u
wait, shin, are we talking about your animation or the rapture one, this thread is about the rapture rom... I have no idea what size your ani is, but this one is like 26mb.
yes, I would take out a lot of the frames apollo
there is another issue
On my warp i have the issue that it will not wake up and ring when i recieve a call when the phone hasn't been used for about an hour and will send calls straight to voice mail (text messages also are not delivered until phone is beeing woken up by pressing power button)
EDIT: I found that it does this when the network is set to evdo only
when i switch it back to CDMA/EVDO the phone will ring
the phone does not loose connection since when it is beeing woken up it instantly has 5 bars
any ideas from the community will be apreciated (yes i have set it back to cdma/evdo but the phone is so much faster internet wise when on evdo only)
so you made a theme with uot kitchen and didn't use boot animation mod... and it loaded fine?
Who did? I havnt been able to get one to work on this ROM it always bootloops it im going to try monday when im at the library along with putting the crt effects into the zip and i will get the new animation from shinru and add that
if anyone wants the non overclocked kernel to flash with this rom, here is the link: 7_nC_b08c.zip
I think some of our phones just can't handle the overclock. The rest of the ROM works just about perfect for me, I did loose root, but just reflashed superuser SuperUser.zip
I built a ROM where the artist would not fear the censor where the great would not be constrained by the small where the scientist would not be bound by petty morality so i ask you my friends if you live with pride would you kill the innocent? Would you sacrifice your humanity? We all make choices, but in the end the choices make us!
I present RAPTURE!
WOULD YOU KINDLY PRESS THIS LINK!!
http://db.tt/yzCxwTjP
DOWNLOAD INSTRUCTION!
1) clear cache and dalvik
2)install ZIP from SD*
3)reboot phone
4)enjoy**
For a future update it wont connect to 520Plantronics device
Bluetooth? Did you try fixing permissions? If you read theres a problem woth a2sd might be why it wont connect
Well ill try to get everything fixed ive been pretty busy
I present RAPTURE!
3)reboot phone
4)enjoy**
What do you use, a bluetooth earpiece? or your car has bluetooth? (I have bluetooth frozen b/c i don't ever use it ;\)Please please please fix bluetooth not connecting bug as soon as you have the time this is a super fast rom i loveeeeeeeeeeeeee iiiiiiiiitttttttttttt.thnx
