UnknownUser1
Android Expert
Havnt found anything to change our prl? When i was running stock i had seen a hidden menu apk and i couldnt find it on this rom do you have the stock you could glance thru
Congratulations!!!! A week without a smoke is a HUGE deal. You should be very proud of yourself.You can do it man! I've been smoke free for...a week! Its been hard. But I'm managing! Its nice, I can wake up and BREATH.
What is the hidden menu for and how do you access it? Thanks.http://db.tt/zf5PzXXd
theres the hidden menu
Do you know where I can find a reference list of the dial codes for the Warp?The hidden menu is exactly what it is when you use ##DATA# and all those codes your bringing up the hidden menu
Thanks, prinny. I hit on it after I posted. I should have waited a moment before jumping on here. Sorry to cause you extra work but thank you for the quick reply.Sprint/Boost ## codes for the ZTE Warp - Android Forums
Try this one out. Should be the right one I think.
Love my new setup with customized ics spectrum live wallpaper
That's why he should make an alternate theme for the ROM![]()
Do what your heart tells you to do and best wishes to you on whatever the direction you choose. I'll miss this rom if you take it completely offline. Will you release ver 1.0C and then stop? What do you want to do with another ROM once you finish with the LG port? Will you continue to develop for the Warp?I wanna make another ROM so I might discontinue this one soon plus I'll be making a ROM over at the LG spectrum forums
