HawgHunter
I noticed there are two 3g icons that appear. When the larger 3g with the arrows on the side is present in the notification bar, I have no service and I refer to this one as the large 3g. When the smaller 3g with the arrows next to it is present in the notification bar I have service and I call this one my small 3g. I'm not sure what the difference is to you, the developer, but to me, the small 3g is the one I have service and the large one I have no service. After I rebooted twice, I had only the small 3g with service show up. I don't know what happened to the large 3g.Okay so I called boost they said the tower I was on was a down tower told me to update (still says 61009) so let's see if they actually changed
When I turn off wifi, my 3g doesn't work and I have to reboot to regain 3g. If I delete the changes you made to the build.prop file, with it be fixed? If I remove those lines, what other tweaks are lost or affected? Thanks.
